High Idle and sluggish?
LongBeachQ45
Car: 1997 Q45/Cima Hybrid
I recently had the engine of my 90 Q occasionally having a parking idle of 1500 and drive idle of about 1000. It is also a tad sluggish it seems. I was wondering if someone could tell me what may be causing this. I replaced the MAF sensor 2 weeks ago, cleaned the throttle body, and tested the fuel injectors with a voltmeter and everything is a go. As far as I know, my car hasn't had the chain guides replaced yet, and the engine barely reached 90K miles. This started last week, any ideas?
Raxephon
Car: '04 RX8...for the moment...
A/C on or off?
Is the idle constant or does it fluctuate?
MAF new or used?
Any leaks?
Done anything to the AAC valve?
Why, in the name of the great maker, haven't you done the guides?
LongBeachQ45
It will only occasionally have a higher idle, but normally it is fine. The MAF was new, and I have only had the car about 1 month so I dont know where to get the chain guides as a complete set. I have found pieces here and there, but need to know all the parts required to do the job (i plan to drop the oil pan too, so chain guides plus all gaskets ans oil pan gasket prices and where to get the would be helpful!!!) I live off the beach in southern California, so I never really need the A/C, it is always off. Any suggestions would help.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
LongBeachQ45 wrote:I have only had the car about 1 month so I dont know where to get the chain guides as a complete set. ....... Any suggestions would help.
http://www.everythinginfiniti.com
One month is long enough without addressing this problem berfore the engine is ever turned again. Ever thought you might already have jumped a sprocket and are a crank away from totaling your engine?
A few years ago this board alone had 3 Q45 1992 that met death by guide failure in a six month period.
Modified by maxnix at 10:32 PM 8/6/2006
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
moved to the online mechanic...
Have you checked anything, like your ECU codes or transmission codes??? Thats a big help if you can do that!
FarFetched
Car: Suzuki SV1000S.
Sounds like a vacuum leak.
