high idle and check engine light
muscleinc1320
Car: 1991 nissan 240sx along with many others
just rebuilt my KA to all stock. The motor runs and starts great but it automatically idles at 2k rpm and climbs to 2500 and stays there after awhile of running. the idle is smooth the whole time also. the check engine light comes on when going up to 2500 and stays on. I believe i have the timing set correctly at 20 when i set it i wasnt sure if the TPS needed to be connected or disconnected. i want to check the engine codes but forgot how to put the ecu into mode 3 so i can read the codes. any help is appreciated. thanks.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Just turn the knob on the side of your ECM to get Mode III. Report back with codes. Do you have a vacuum leak somewhere?
muscleinc1320
how will i know its in the right mode. i know last time i have difficultly knowing which mode was which. also i thought there might be a leak but i have yet to find any. im still going through looking for any broken or old lines i might or should replace. just in case.
blueballa
Car: 97 kouki
check your egr as well.
