Zwicked »
https://forums.nicoclub.com/zwicked-u65277.html
Thu Jan 31, 2008 7:09 am
Test the AAC solenoid before you reconnect the wire. Run a 12 volt +/- wires to it and touch the 2 terminals momentarily. You should be able to hear the solenoid click. If not it might be dead. The ECU is rapidly and constantly modulating the AAC, so it is a very important item to have working correctly.If it's ok, then set the idle with engine warm to about 600 RMP and then plug the connector back onto the solenoid. It should immediately raise the idle to about 650~700. At that point you will know the AAC is doing it's job.
For the AAV, you need to take it off, but try testing it first.Take a pair of long nose pliers or vise-grips. Clamp the hose off that's on one side or the other of the AAV. If your idle goes back to normal, you've found the problem.
Luckily there are only 2 easy to get to bolts (relatively speaking!) and no gasket or anything as it is just secured to the plenum. Once it's off, look into the hole where the hose connects. You should be able to see a crescent shaped hole through the other side. Connect 12 volts +/- to the 2 terminals and let it sit for a few minutes. That disc should have now closed and you should not be able to see through it. This is what lets extra air in for raising the idle, and closes off to return it to normal idle.If it doesn't seem to work take it apart and see if it's clogged/seized with oil. If it's not, it likely means the bi-metal spring is cooked. I have a few extra of these, so if yours is bad you can have one if you pay the shipping from Canada.
Just one question: I assume you have checked your throttle and cruise cables etc to ensure the throttle bodies are fully closing?
Modified by Zwicked at 9:38 AM 1/31/2008
Modified by Zwicked at 9:39 AM 1/31/2008
