kpc_0721 »
https://forums.nicoclub.com/kpc-0721-u55261.html
Sun May 31, 2009 8:45 am
So I'm confused, the car sat a few days because I didn't feel like working on it after work and started it up and it was at about 1400rpm.
unplugged the maf and for a split second it changed then went right back to the 1400rpm. Turned the car off, started it back up and it jumped right up to 4000rpms.
When it was running at 1400rpms it wasn't very smooth and was running very rich and white smoke coming out of the exhaust.
I know white smoke usually means a bad headgasket but it doesn't smoke when it is idleing at 4000.
Any clue what is going on with my car?
If the head gasket did go bad could it cause the car to idle like that?
The weird thing is that if the car sits for a day or 2 and I start it it won't shoot up to 4000rpms but to around 1400. Then after I shut the car off and start it, it goes back up to 4000rpms
Don't think it is a vacuum leak, just gone done spraying the piss out of the intake manifold with brake cleaner and no change in idle.
