high idle 3000rpm
slowasss13
Car: s13 sr20det tomai o2 housing blits down pipe hks pro power exhust greddy v spec inercooler 6 puck s
its an s13 redtop in a s13 the car idels around 2500-3000 rpm untill i pinch off the hose going from the ic piping to the iac. then it will idel right around 1000 rpm but if i pinch the hose all the way it shuts off . i have a spare iac but it look like hell to do . do u think its my iac or a vac leak after the throtttle body ? i tryed the old carb cleaner trick and no change in idel , plz help me i miss driving her !!!!! sean
alwaysS13
Car: '89 S13 Sil40
bump
GoTRicEo0
Car: Slowest crap the earth have ever seen.
there's a big screw on the IAC (Phillips) Tighten that and see if anything changes.
SlowTK
I'm also having the same issue with my car. I have already replaced the IACV (after adjusting the screw, which did nothing). The only difference is that my car idles around 2k... it's not horrible but makes me grit my teeth when it's cold out and doing a cold start.
