high HP Fuel line solution
CA19DET
well i have been looking for fuel line solutions and found this on Summit Racing website
Quote »Pain-free fuel delivery from Summit.
Filter to pump to carburetor, 25 ft. 3/8 in. aluminum line, 3 ft. stainless steel braided hose, fuel line and fitting kit
Have a fuel delivery dilemma? This Summit Fuel Line Combination Kit can help. Designed to work with 3/8 in. NPT components (regulators, pumps, filters), the kit contains all the fuel line, fittings, hose ends, and assorted accessories you need to run your fuel line from your filter to your fuel pump and up to your carb. It's easy, it's quick, and it's pain free. The kit does not include fittings to hook up to the carburetor.
Sold as a kit. - $59.00
[/quote]what do you guys think??
slw240sx
Car: 1990 Ca18det 240sx Hatch
will it work on highpressure fuelinjection setup?
CA19DET
i am pretty sure its jsut a fuel line, it doesnt come with the fittings so you jsut got to get that, but the guys on freshalloy think thats it may be over kill...
themadscientist
yes. I've found the HICAS line makes a great fuel line with some hose juggling;)
Xero
I was gonna get some thicker solid lines, and bend them myself, then get some SS fuel lines for the flexy stuff, no need for a kit.
ca18datsun510
Car: bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
your post says it comes with a fitting kit, then you say your pretty sure its just a line. this would be good with a upgraded pump and a pressure regulater. use the stock feed as a return line, and ditch the factory return line. i am currently drunk, so ill check back in the morning and see if i still agree wtih this.
CA19DET
what i meant is that it has fitting to connect to the pump & filter but not to the fuel rail, and the fittings supplied with the kit are for Carb'd muscle cars, and may not work, but fittings are easy to get
