trpower7 »
https://forums.nicoclub.com/trpower7-u205.html
Sun Nov 16, 2003 3:06 pm
At least for now I wouldn't trust anything said on this board. There are now hundreds of absolutely stupid newbies that have NO CLUE what they are talking about and feel free to give advice. Please keep your traps shut and leave it to us veterans who know exactly what we're talking about.
AUTOMATIC TRANSMISSIONS HAVE NO CLUTCHES EXPOSED TO FLUID!!!!!! They have many small clutch PACKS that are sealed, and are in virtually NO way similar to the clutch assembly in a manual transmission vehicle. If your clutch is slipping, it has NOTHING TO DO WITH ANY KIND OF OIL AT ALL, unless as above stated you uber-overfilled your transmission and blew out the seal. That is unlikely. Your clutch is bad, it's a cheap one, probably not broken in correctly. The phrase "A/T clutch" is something that is absolutely non-existent. In automatic transmissions the fluid is a hydraulic fluid used to change gearsets, lubricate, absorb heat, etc, it has nothing to do with any kind of clutch.
