good find, but they don't say if it will be for KA24DE or KA24E...Warped wrote:http://www.amzperformance.com/...b112a&
just thought i would share i haven't called for a price yet
according to the picture it's for the DOHC. while I agree with your statment if you're rebuilding the motor and the cost isnt that much over a stocker, why not go with a higher volume pump?Checkered-Member wrote:
also $$$$$$$$$$
i have yet to see a KA-T fail because the stock oil pump couldn’t supply enough oil
How exactly do you replace the oil pump? ThanksImport_Ant wrote:For us SOHC people the 280x turbo fuel pump is a direct replacement/upgrade for the stock oil pump and it flows higher volume. They can be had for 75$ on http://www.hybridka.com (I'm planning on getting one for the motor i'm rebuilding)
Pictures & instructions my friend? THANKS!Import_Ant wrote:I'll take some pics tonight for you.
mwaahaha i love the SOHC motor. I'll get off my lazy *** and take apart the oil pump and do a write up for the SOHC motor since i do have that paperweight sitting on the stand...fiznat wrote:Its a real pain. You need to remove the crank pulley and lower timing cover... More a weekend job than an afternoon one, and you can run into some potential problems if things arent done right.
A nice DIY with pics would be sweeeet, though. I'd do it myself but, heh, the job is a little different when your block is laying sideways on the garage floor with 8 holes in it.
Yes my friend, detailed writeup w/ pics - post here so we know you have a writeup once u finish :-D.Import_Ant wrote:agreed, it'd just be cool for everyone I think if there was a more detailed writeup w/ pictures and torque specs of the bolts I think.
FWD maybe?... no on second thought that looks like a picture for a Honda oil pump.koukiKA240 wrote:fyi, that is not a picture of any ka lower timing chain cover/pump. the bolt locations are all wrong and it isnt even tall enough to meet with the uper cover.~Sam
