wow, really? where have you seen that? particular brands? one would think they'd be in serious trouble if they were marketing something that was simply a resonator as a hi-flow cat, I never failed emissions with my Catco. Like i said, you can see thru the hi-flows, but it's a kaleidoscope thing, it's not a gaping hole as there is still some honeycomb packing in there. That's interesting to hear though.Scooby24 wrote:A lot of what I've seen labelled "high flow" cats are really just resonators...they are straight through and perform no smog purpose.
It's totally untrue. First off, a resonator is something specifically designed to cancel out sound waves, not just a piece of pipe. Plus, like you said, you can see the catalysts inside them.skydragoness wrote:wow, really? where have you seen that? particular brands? one would think they'd be in serious trouble if they were marketing something that was simply a resonator as a hi-flow cat, I never failed emissions with my Catco. Like i said, you can see thru the hi-flows, but it's a kaleidoscope thing, it's not a gaping hole as there is still some honeycomb packing in there. That's interesting to hear though.
No it is completely true. Usually the ones I see that are just resonators are on ebay....labelled as "Resonator Hi Flow Catalytic Converter"....they state inside the ad that they are for "off-road use only" but many don't state they aren't actually a cat so if the buyer was not very savvy they would be duped into thinking they were buying a replacement catalytic converter.InsanityInc wrote:
