High flow cats + stillen exhaust
dmpball
Car: 2003 Infiniti G35 Coupe 6MT
well its official, my new stillen exhaust is on the way, which leaves me with only one problem...what to do about the strikingly bare front end of those brand new pipes. I was looking at a set of Kinetix high flow cats to slap on there and complete the whole system, but i have yet to order those, (my mind needs time to catch up with the bills that my fingers just clicked away). so anyway, i need some opinions from the pros...do i
A. Throw on the exhaust first chance i get, and toss the cats on laterB. Wait to put the exhaust on until i have the cats, so i get it done in one shotorC. Say to the cats because they are not worth it and my dealer is going to void my warantee and that would be BAD.
thanks again for the input...and the modding bug
gwoods
Car: 2013 Infiniti M37x
1999 Nissan Altima SE limited 5spd
1992 Miata (soon to be turbo)
1965 Cj-5 with 327 v8
2012 Toyota Sequoia Limited
Do it all in one shot... unless you really really like being under the car.
I would do high flow cats unless you are planning to run nitrous.. then do no cats.
Jeff
Jacko3
Hello Jeff:
Just like you, I just ordered a few mod parts as well. I learnt a great deal from this forum, and I agree, the cost of moding a car can be painful after so many clicks on the web.
Well, I didn't worry so much about my cats and headers. Rather I decided to do JWT Pop Charger with z-tube, 5/16" Plenum spacer, Mrev2, and Stillen Cat-back exhaust. I will be installing all of it at one time. My next plan would be to install a non-underdrive Unorthodox pulley set with may be a high flow cat, and perhaps drop the height of the car with an eiback coil set. I have been assured that i would love the car, more. I shall wait and see. Good luck with yiur mods. Installing everything at one time is a very good idea. Most people don't install it all at once because of costs. So, if you have the money, why not do it all at once, and enjoy the full benefits?
pae9132
Car: Modified 03 V35
how are the smogging laws and how soon is it until your next smog? I live in CA so it sucks out here. Unless you are going to do the cats yourself you will be spending money everytime you have to smog to get them taken off and then to have them reinstalled.
toddnos
Car: 2003 infiniti g35 sedan
pae9132 wrote:how are the smogging laws and how soon is it until your next smog? I live in CA so it sucks out here. Unless you are going to do the cats yourself you will be spending money everytime you have to smog to get them taken off and then to have them reinstalled.
if they are high flow cats, they will pass smog...test pipes will not. no need to remove them when you smog...i hate mis information.
rn79870
Car: 2008 G35 & 2005 Vette C6 vert.
Make sure that the high flow cats you get ARE CARB (California Air Resource Board) approved, and therefore will pass smog. If you live in CA, make sure everything you do to your car has a CARB number, and save it, because the Smog mech doing your inspection may need to see the list and the CARB approval number before passing your car. The alternative is that you will get bounced to a referee station, and that could be a real PITA for you and your car.
(this post assumes you live or are moving to California - if you don't YMMV)
Modified by rn79870 at 7:31 AM 1/29/2008
pae9132
thanks for adding that info rn79870...that's exactly what I was talking about...I just don't know if other states are as strict as CA...and the last time I checked the CA law stated that the cats could not be replaced at all unless the original cats were found to be faulty...so I don't feel that any "mis information" has been put out
dmpball
Thanks for all the info. I live in NJ so unless someone has any information on this state, i don't believe i need to get CARB numbers for inspection. And no i was not going to put on test pipes...just high flow cats, and from what i've read, the cats have passed emmisions testing, but they do not have a CARB number with them, but again since i dont live in CA i dont think that should be a problem.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
no, you should be fine
CA is just really stringent
it is always good to go with CARB certified parts though just in case laws change...
BrandAidDesignG35
Car: 04 Infiniti G35 Sedan
My idiot father took my first car into the shop for inspection...
I had 2000 worth of exhaust / header / straight pipes / mods on the car... WHICH FAILED emmissions... of course, and, had to be replaced with OEM bafflers and cats and silencers
not to mention the cost of new exhaust (500)... Make sure you have a buddy inspecting or swap the pipes yourself.... This is definately a ****ty way to lose HP... and invested $, time, and sanity...
Take my advise, it's best to go high flow cat route...
That's what I plan for my G35.
Grant
rn79870
Ouch, ^ that was an expensive lesson. I'll bet the EPA, or whatever the equivalent Canadian agency has approvals/permission references for these aftermarket parts too. It might be worth a little investigating before buying stuff for your Gs.
BrandAidDesignG35
The Stillen high flow cats are expensive, but that's OK cause they are CARB legal, and claim to be fine on emmissions testing...while improving hp nearly as much as a test pipe!
Sounds good to me!
560 USD!
dmpball
Stillen cats are a lot of $. thats the main reason i was looking at a kinetix pair...their about $150 less, and they wont throw a check engine light
BrandAidDesignG35
Are they available in canada? around 400 US??
I was unaware the stillens would mess your ecu.?
Either way... An emmisions passing car is the way to go... THINK OF THE ENVIRONMENT!!!
I spend like 600 bucks a month on gas.. which is OK, but I feel bad for global warming.
dmpball
check their website http://www.kinetixracing.com and see if they will ship to canada.
and idk if the stillens will throw a light...its not posted on their website and i dont really have a need to research them, i've heard good things about the kinetix pair, so thats what i'm going with
toddnos
pae9132 wrote:thanks for adding that info rn79870...that's exactly what I was talking about...I just don't know if other states are as strict as CA...and the last time I checked the CA law stated that the cats could not be replaced at all unless the original cats were found to be faulty...so I don't feel that any "mis information" has been put out
regurgitated info then....ive put high flow cats on cars in socal..i know they pass...carsound makes good highflo cat conv....who the f is going to know if your original cats were faulty....the cat fairy? pfffftttt!
pae9132
http://www.catalyticconverter.org/law/index.htm
Just want to put this info out there so everyone knows what they are getting into. Thats what this forum is for.
pae9132
