High Flow Catalytic Converter
DeeZNuTTss
Car: 240sx 4/1991 hatchback s13
was looking for one but don't know which would make a differecne or not.i heard the install might be a pain is it? what about the performance? does it make a difference? and what about the sound of my exhaust would it change that?
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
replacing a catalytic converter has to be the easyest thing on the planet, if you can play with legos, you can replace a catalytic converter. It will make your car run cleaner because its new, but it wll probably perform only marginally better. You car will sound the same as it did before.
deftdrummer
Car: cars, drums, music, technology
where can you even buy one? cheapest ive found stock convertors was http://www.catylaticconverters.com (probably not spelled right) and for the 240 they are like $96 that's for a stock one though. I haven't been able to find high flow ones really
Structure240sx
catco makes one that some people use, buudweizer dout i spell it right uses one on his SR
BuudWeizErr
yeah, i have a 3" Catco on my car.
Got it from Heavy Throttle.
deftdrummer
so it just bolts right in and replaces the stock cat even though its 3"?? is it worth $139? cause i can get a stock cat for like $89
Structure240sx
well its 3" so it will flow a little better than a stock one
deftdrummer
hmmm oh well
Onizuka
it really isnt the diamiter, its the flow rate through the mesh material in the cat. I also got my 3" cat from heavythrottle.
Eswift
Car: should be obvious enough
catco or random technologies
deftdrummer
ill probably get one then. along with the hotshot header, that should clear up all exhaust probs!
Onizuka
it helped me pass emmisions.
