see this thread about the serpentine belt post6571550.html?hilit=serpentine%20belt#p6571550ashkar wrote:Thank you darylzero for the video. It is really helpful. I got a new Dayco belt #5060710 which was very tight to put in and soon I will be replacing it with Gate brand belt. It is a bit longer than Dayco belt and hopefully won't make any noise. It looks like the goodyear belt does a good job of reducing noise and I was not aware of the alignment being something to check for. I have some little movement in the AC pulley but not sure if that is normal or not. I will put the new Gate belt on soon and check all pulleys too. I will share an update with what ever I find. Thank you again for your feedback.
