NolimitZ32 »
https://forums.nicoclub.com/nolimitz32-u100070.html
Wed Oct 15, 2014 6:10 am
In regards to your original question; it has been done, throughout my years of learning and searching everything VG I have seen a random video here and there of VGs with raised compression, not exactly sure to what. I don't remeber the exact numbers but I believe honad was able to put close to 200 to the wheels from a lightened to hell (driveline and all) stock engined NA, you'd have to search the forums. As for HC VG, its possible just like everything else, with enough cash. It will never be worth it unless you want the bragging rights. Figure about 5k for lightened rotating assembly with shaved crank and custom rods and pistons as well as another 5k into a full titanium camtrain with custom grinds on the cams. A hell of a lot of custom tuning, custom intake and exhaust manifolds designed to provide the proper scavenging, etc, etc, etc. Theoretically (from an engineering standpoint) YES it can be done, realistically unless you are willing to drop a massive sum of cash and still be eaten alive by some of the mildly built TTs then it's not possible. The VG30DE was designed with boost in mind, it was the basis for the massive intake manifold, the port sizing, the cams, etc. I once had a dream of building some one off stuff, even went as far as doing design and calculations on sizing ITBs, lower plenum, ambient air charge chambers, and some other goodies but at the end of the day I gave up because it was way to expensive to build those one offs. Instead I spent an egregious amount of money on my TT and couldnt be happier. If you don't want to do a bastard swap (thats what I call it when you end up with a SBC or 2JZ in a Nissan) then I would suggest going the route so many others have taken, build a TT out of your NA (since you already have the engine) all you really need to do internally is install some low comp forged pistons or even some factory TT pumpers which can be had for next to nothing. Going that route however, all your money will go to the bolt-ons starting with turbos and factory or custom piping all the way to the oil lines, boost controller, and other little s*** and bits.
