You will want to get a really good tune from a pro who is confidante in tuning high compression and/or boost applications. I would talk to some one who will tune it and get input on your set up. I like the high compression motor sound! 11:1 is not insane but Im not sure about a gt30 and 11:1 compression on pump gas.DawgMode wrote:wassup guys,i have a s14 sr with a gt30 setup and im looking to put pistons in my car, but the thing is i want to do a crazy high compression setup. im looking at around 10.5- 11:1 compression pistons with stock bore. any inputs on what piston manufacturer i should inquire on and if this is a sane idea
im sorry for thead jackbut could you explain teh high compressoin motor "sound"ive never heard anyone say that..supreamS14 wrote: I like the high compression motor sound! gas.
If you go to the drag strip and listen to some drag cars that run high compression you can hear a crackeling sound. Alot of muscle car's with V8's that have that crackel sound run race gas.E7-S14 wrote:but could you explain teh high compressoin motor "sound"
So you're loosing power then?DawgMode wrote:well we run AV gas down here so fuel wont be an issue
Because it's more reliable and you have better off boost response... Not to mention the potential to make crazy amounts of power when the boost is jacked up.. Honda guys do it all the time and it's not uncommon to see 500-600whp with a 10:1 motor at 15-20lbs of boost...srdub-t wrote:why do you want such high comp.. just do 9:1 with more boost and youll make alot of power safely.. i dont see the point in high comp with low boost.. waste of mony in my opinion
