ProdOfFL »
https://forums.nicoclub.com/prodoffl-u37027.html
Mon Jan 08, 2007 4:30 am
This is awsome, I can't believe I'm getting so much help. I haven't really looked at the Biki. This weekend was pretty rough. Had to buy a new Radiator, so I wasn't really looking at much other than cooling. I've looked into some of the stock ECU options and there's a ton out there. The E-manage piggyback may be the best way to go cause of the Aux channels. I'll need to run a wideband, so that'll be usefull for sure. There's a guy around here that's running one on his all motor Supra w/ no problems I'm pretty sure. I'm waiting to catch up w/ him again cause I missed out this weekend. I'm looking at the JWT ecu I already have, but reprogrammed w/ the E-manage ultimate. Should work out pretty good.The cams are aggressive for sure, but my machine shop is going to flycut the pistons once he gets the head. He's going to do the assy so it has a warranty. The only problem is that Wilson wants the head for 14-16 weeks to make the one-off manifold. Then I'm sure they'll want it another month for the Nitrous plumbing. So it's gonna be a while longer than I thought. Should be running by summer. The motor should break into the 10's on the kit w/ just +500 to the crank. That's what the program says at the machine shop. Still looking at a few progressive controllers to do the trick, but Pro-Flow is looking pretty good. They're owned by Wilson and the domestic guys swear by them. They run alot bigger shots and temps than I'm gonna run, so I think I'm safe.
Once again, thanks for all the help and keep the info coming. Wanna do it right the first time, and other people's experiences are the best ways. Thanks!!
There's alot still ahead
