deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Sat Apr 16, 2005 8:06 pm
The ka24de does have limited valve to piston clearance. How long of duration cams and how much lift are you planning to run?
For instance, a "hot" oem cam setup 248/248 at base setting (with cam gears) combined with early 89 ka24e pistons (.020" over the 34mm compression distance) yeilds less than .015" exhaust valve clearance. That is with a fresh timing chain assembly, any slack in chain retarding the cam timing will obviously provide less clearance.
This is very slim on that particular setup (to slim), but using different pistons can give a lot more room. Late 89-90 240sx or stanza ka24e pistons are .040" lower in the area that the exhaust valves come close (.020" lower than the 34mm compression distance). I would suggest an exhaust valve to piston clearance of at least .030".
As with any custom high compression and cam setup you will want to verify with your engine assembled with one of the piston tops covered in .070" or so worth of modeling clay. This adds another step to the assembly process but is a must. If you find that clearance is minimal after all of your desired components, best course of action is advancing the exhaust cam with an adjustable cam gear. If that does not do the trick with just a minor degree adjustment, you will need to flycut your piston tops. Custom pistons can be ordered/designed with valve relief/flycut, or the pistons added dome volume can be positioned away or around the valves.
What are your desired specs or parts that you want to end up with (compression ratio, cam lift/duration)? I may be able to give you a better idea of whats necessary.
