DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Sun Jun 18, 2006 5:33 pm
i dont think you are saying what you meant to say. overlap occurs if you are cranking the motor around at 10 rpm by hand, not just at high revs. overlap is good for high revs, but it doesnt just suddenly appear. perhaps this is a case of semantics, but a set of JWT N/A cam gears does have a lot of duration, now they also have a lot of overlap too. So actually they are two seperate occurances, as you could have a bunch of overlap and a short duration (if you were a moron with adj cam gears or something ridiculous, just an example). So who knows, the bottom line is, i agree the cams shouldnt affect compression results too much. If you had to sacrifice compression for bumpsticks, you'd be pissed off at your investment. The cams shouldn't lower compression significantly, bottom line.
Now, with that said, me and Ajax already figured this one out, and no one would ever have come up with the answer, because it is infact ridiculous. I'm not at liberty to say at this point, however
