http://www.racetep.com has 200hp N/A engines for under 4000. I am not sure if that is CRANK or WHEEL. I was going look into for mt Altima, but gave up because it was autotragic.....might be good for someoen who wants tyo stay N/A to check in to.
Nissan 240SX and Altima
( KA24e & KA24De )
210 HP Normally Aspirated Street Engine Mods.
For those of you that want fun streetable power without all the expense of a Turbo system we have developed a great engine combination suitable for everyday driving on 93 octane pump gas.
Low to mid 14 second ¼ mile times without abusing your driveline or using Nitrous. For those of you hell bent on using Nitrous the JE Forged pistons and special Total-Seal Ring pack we use will easily handle 60-70 HP of NOS without too much worry. If you want a bottle only motor or plan on running a 100+ HP unit we can supply specially designed and coated Nitrous Pistons and valves.
All engines are done on your core or we can supply a core and sell it on an outright basis. Core cost is approx. $650.00. Shipping anywhere in the U.S. ranges from $150.00 to $250.00 for complete engines depending on where you are.
Complete Engine build-up includes….
· .040 overbore 10.5:1 JE Pistons
· Total-Seal Ring pack
· Race prepped stock rods with ARP bolts
· Detailed and Heat Treated crankshaft
· Lightened stock Flywheel
· Balanced and Blueprinted rotating assembly
· Race Ported, Flowed, CC’d Cylinder Head
· 3 Angle racing valve job with hand lap and back-cut
· Secondary Butterfly system removed.
· Intake manifold match ported.
· Throttle body opening enlarged for 65mm T/Body.
· Camshafts reground and indexed.
· Valves shimmed and adjusted.
· Heavy Duty Head Bolts.
· Felpro Gaskets
$3900.00 complete
Optional Upgrades:
Ceramic coat pistons for Nitrous use $49.00 ea
High Heat coat valves for Nitrous use $9.00 ea
Enlarge stock throttle body to 65mm $250.00
