wrong.Projekt wrote:that's only true on a belted engine. all mazdas have corresponding valve reliefs. same with hondas. if you have a timing chain instead of a belt it's not a problem. the reliefs are for insurence against a broken belt.
valve reliefs are needed to keep the vavles from making contact with the pistons during normal operation. they won't protect your engine if your timing belt or chain fails.
also, it doesn't matter if it has a belt or chain, if it is an interference engine (which applies to about 90% of the engines built in the last 2 decades) you are looking at disaster when the timing chain or belt breaks.
-demetrius
