Fint »
https://forums.nicoclub.com/fint-u43828.html
Sat Dec 16, 2006 6:37 am
Hey guys, I'm posting this for a friend. He has a high comp (11.1:1) bore'd over KA24DE. Right now the engine takes a long time to start, has loud pops from the intake manifold and sometimes doesn't want to run. He has to give it light then hard throttle to get it to run right. We tried many things, cam timing, drain fuel tank, test charging system, knock sensor, MAF, etc. We recently tested the fuel pressure, it would jump in between 30psi to 45psi and at time up to 60psi. I suggested a Walboro and adjustable FPR. Anyone else have this problem or any suggestions? Thanks
-Fint
