DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Thu Jan 26, 2006 5:34 pm
i bet they didnt bleed it right if they replaced the slave
the clutch resevoir needs to be unbolted from the car and you need to physically raise it as high as you can to get rid of the air bubble, or bleed it for hours on end....
if you look at the hardlines going to the resevoir you'll notice it is actually higher than the resevoir itself, no amount of bleeding will ever get air that is trapped up there out of it. so you need to unbolt the resevoir and bend the hardline slightly with the cap off, almost instantly you'll hear the rush of air
i never like the idea of adjusting the pedal, thats what everyone does, they never actually adress whats wrong, they just go for the quick fix, when this is clearly the problem. This car was clearly designed to be RHD, where the hadline wouldn't even even cross the engine bay
