WhatsADSM »
https://forums.nicoclub.com/whatsadsm-u29596.html
Tue Jun 16, 2009 5:35 am
I always wanted to get a thread together with people who are willing, to put their timing maps up. Glad we have at least some version of that!
Timing is EXTREMELY dependent on the burn rate of the fuel you are using. So to be honest with you, us telling you our timing numbers on gas (and/or gas mixtures) really won't do you much good on propane. You will need to go to a dyno along with a known working DET monitor and tune for MBT under low load and a few degrees before knock under high load.
In truth timing is a mix of TONS of variables. Under low load it is pretty easy to get right by using MBT. Under WOT it is a function of fuel properties, KNOCK (most engines die from this NOT AFR/EGT like many think), flow rate, RPM, IATs, brake torque, AFRs, EGTs, and engine stength/desired duty... Not really a simple run XX timing for XX boost.
FWIW, I personally don't like to push the tuning envelope too much on a stock motor being worked hard, and basically s*** for monitoring knock. On e85 (considerably slower burn than 93oct) with I'm guessing somewhere in the low 600bhp @ 20psi, at the top of the gear I am at ~22.5*. I just tuned for a bit more boost (since my fuel will allow that), and at 24psi I have it ~18* at the top. But that is getting awfully close to the limits of the stock engine. For a daily cruise/drag car I am comfortable with that. When I take it road racing, I take a few degrees out and the boost comes down to wastegate pressure (~17-18psi).
Hopefully I can get some more quantified data together once I get some time to finish my knock monitor.
Modified by WhatsADSM at 8:52 AM 6/16/2009
