JiM86 »
https://forums.nicoclub.com/jim86-u215707.html
Mon Feb 11, 2013 1:56 am
Hey guys After doing some searching reguarding pcv/catch can setups I decided to block my pcv up as i'm running a vented catch can I followed a diagram i found on here Now i am not entirley sure if i want to keep it this way The only reason i did was because i was getting oil in my pipes enough to start small pools around the clamps under the piping on the turbo side And was told this was the way to go But now after driving it I went to hit full boost 10psi and got a bit of smoke out the pipe plus some hesitation and it was like i hit fuel cut Checked the gauge im going past 15psi :/ thought i bumped the manual boost controller So i set it again same problem Any help would be appreciated.
