rogermills »
https://forums.nicoclub.com/rogermills-u20628.html
Tue Jan 04, 2005 12:19 pm
Hey, me too!! Right side high beam.
Did you notice that the high beam indicator light will NOT come on?? It is running off the same line as your right high beam line.
And, when you 'click to flash' the high beams [as opposed to completely turning them on], the right high beam & HB indicator light STILL DOES NOT come on. [That should be another part of the relay/switch, so if it DID come on, the problem would be in the relay switch]
PLEASE. someone out there HELP US!!!
240SX '94
