High beams dont work
Oneor1
Car: cars, music, hockey
have a 92 240sx, I've tried replacing the whole headlight housing but the high beams still dont work when I put them on, everything just goes black. I have no idea what it could be. Any help would be much appreciated. Thanks
-Rick Johnson
Pemdas
Car: spinning, 240s, bad *** *****es
i have a similar problem but only one of my high beams works ( drivers side) and the other one doesnt work...beats me
Oneor1
Yupp... thats how mine used to be, then both of them went out, so maybe you have that to look forward to! lol but we gotta get that problem fixed. hopefully someone can shine some light on it.
-Rick
Oneor1
haha no pun intended :D
yellow_jacket
Car: 95 240sx
Have you checked the fuses for the headlights? If its not the fuses it sounds like a dimmer switch problem.
I believe that nissan used one fuse for the left high beam and another fuse for the right high beam, and other fuses for the low beams, tail lights etc. They should be located on the fuse panel that is under the hood.
Oneor1
checked the fuses and nope...neither of them were blown.... would it still be the dimmer switch if the lights in the interior dim like they're supposed to??? Let me know.
-Rick
Oneor1
hey pemdas... got a question... you dont by chance have your inner fenderwell liner removed on your passenger side do you?
Pemdas
Oneor1 wrote:hey pemdas... got a question... you dont by chance have your inner fenderwell liner removed on your passenger side do you?
nope... dont have any fender lining removed, had the splash shield removed for a while cause it was pretty old and torn... but the first thing i did do was check the fuses and they werent blown, but this question about this dimmer switch, where is this located?
Oneor1
Not sure about the location of a dimmer switch..... could this really be the problem?? Surprised more people havent had this problem.
-Rick
yellow_jacket
Car: 95 240sx
The switch is part of the turn signal switch on 240's. It is different than the one for the dash lights.
Oneor1
any idea on where the location of this switch is at?
yellow_jacket
Car: 95 240sx
The turn signal switch that you use to turn on your blinkers is on the front left of the column. I believe that you would have to remove the steering wheel to get at the actual switch, but you should be able to get at the wiring and check that under the kick panel.
