Ace2cool »
https://forums.nicoclub.com/ace2cool-u95120.html
Tue Apr 19, 2011 3:49 am
Hm, that's a tough one. Have you verified if your headlight switch is working properly?
If so, How about the turn signal stalk? I know on older S30's, the Turn signal stalk had pretty much EVERYTHING routed through it, and could cause some screwy things to happen if it was messed up. I'm not sure about the Z32 though, since the S130 didn't have the same issues, due to different wiring.
Also, have you checked any relays? Not sure if the relay would give you the High Beam indicator light, but if it is internally shorted, there is a good possibility of an odd indication. (I can make my buddy's Camaro low beams come on by grounding a wire behind the head unit, so anything is possible) I would check low/high beam indicator relays.
