High beam bulb replacement
Bfish
Car: 1993 Nissan 300zx twin turbo manual tran
Good morning all. I am writing this and asking if anyone knows an easy way to replace the high beam bulbs on a 1993 nissan 300zx TT. They are absolutely buried and I'm wondering if anyone has a tricks to replacing them easily. Thank you!!!!!!
NolimitZ32
Small hands, lube, and a sailor's vocabulary.
Bfish
🤣🤣sounds about right
Bfish
I just got the new twinz bumper and nose installed and I dont want to take it off to remove the headlight assembly :/
NolimitZ32
You shouldn't need to remove the bumper. You may get a little more wiggle room for a couple fingers from the side if you pull off the nose panel but I've done it before from under the hood and I by no means have small hands.
Bfish
I'll give it a shot when I get home 👍
