HIDs installed & ballast placement
prlwhitecoupe
Car: 2008 Pearl White Altima Coupe 2.5 S w/CVT & Premium Pkg.
I bought a 4300K HID kit from a local retail distributor (Speedstar in Markham - http://www.speedstar.ca/) for $280 cash.
These are primarily available from http://xtremehid.com
- Can't wait to install it once this -15 degree weather and crazy snow storms calm down!!
http://www.speedstar.ca/main_h...k.htm
*2nd set of Ballast and Ignitor wires are inside the box
Modified by prlwhitecoupe at 2:11 PM 2/12/2008
Absolute Zero
Car: '08 Nissan Altima Coupe
Instead of screwing into the wheel well cover like some of you have done, I used the 2 curved pieces of the frame that are just inside the cover (I hope you guys know what I am talking about).
This was my mounting method...
I used the double-sided tape first, then ran three really long twist-ties through the three holes on the ballast.
Then I wrapped those around the frame but didn't tighten them all the way.
Then I used about 4 huge zip-ties around the whole ballast and frame together and tightened them fully.
Then I went back and tightened the twist-ties.
(I did pretty much the same for the ignitors, except that it didn't have screw holes so I just had to zip-tie them alot.)
Just wanted to share another option instead of drilling.
team_work
Car: 2006 G35 coupe
does putting in the hids on the headlights and fogs do anything in regards to the warranty on the vehicle? i want to get hids but dont want to void the cars factory warranty or the dealers. thanks in advance
