HID to halogen bulbs
ipunchfireintheface
Car: 2001 Infinity QX4
Hey everyone. First time poster here. I bought a 2001 QX4 back in May and I gotta say I love this car. My problem is that my passenger side HID went out. As much as I want to replace it with another HID bulb I can't really afford it right now. I was curious if you can by-pass the ballasts and put regualar hallogen bulbs in and if its easy to do. I want to just do plug and play, not get into cutting wires and stuff cause I would like to use the HIDs again someday.
Thanks!
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
I don't think it's possible to just connect the ballast wiring harness into the headlight harness even if the physical shape is the same. Plus a halogen bulb will probably not look correct in a reflector housing.
Are you certain the bulb itself has died? You can try to swap the two bulbs to see if the problem follows.
Welcome to NICO.
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1997 Maxima 5spd Supercharged
1995 240SX S14.5
1995 240SX S14
1994 Hardbody KC V6 5spd 4WD
1972 BMW 2002
1972 BMW E9
If its just a bulb I can get you a pair for about the cost of a decent lunch for two, and if you need a ballast a used OEM is always a budget friendly alternative.
If you need any help let me know
ipunchfireintheface
Thanks for the replys. Local parts place quoted me $103 for the bulb. What would be a good place on line to find them? Do I have to worry about them breaking in shipping?
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1995 240SX S14.5
1995 240SX S14
1972 BMW 2002
1972 BMW E9
I can get you a pair for $30 shipped, basically its the difference between oem and aftermarket expensive, and aftermarket cheap. I run these bulbs in my QX4 and have since 2007. Do however make sure it is the bulb thats the problem and not the ballast.
