smockers83 »
https://forums.nicoclub.com/smockers83-u49766.html
Fri Dec 14, 2007 6:37 am
No, the HIDs and fogs are different bulbs. Here's the thing with fog lamps that I don't think people quite understand. The reason fog lamps have the yellowish hue like halogen headlamps is because it has a longer wavelength than a higher K bulb and illuminates the road right in front of you much better because the light gets scattered all over. A higher K bulb's light gets reflected in a more direct path, so depending on which way a particular beam goes, it may not illuminate the road. So if you live in an area with fog, heavy rains, or heavy snow (particularly snow because it'll reflect right back at you), this may not be a good idea. The aftermarket driving/fog lamps that you buy that are HID, the people that buy those use them for the looks and/or as driving lamps, so they make them in HID for those purposes. I have to say it does look cool, but the functionality is reduced and it can be potentially hazardous to other drivers due to the increased output (I've had friends ordered by cops to take theirs off here in MI so apparently there's a cap in output here?).
