Greetings all from Maxima.org! I'm a new member here (obviously) and a first time Altima owner (08 2.5S), but I've been a member on Maxima.org and a Maxima owner for the past few years so I'm not too noob Anyways, as my first post here, I'd like to help out some of you sedan guys who may be confused about installing HID's, bumper removal etc. YES, I'm fully aware that there are several other HID topics floating around where this may have been clarified, but I'm just trying to clear up a few things for those who still may be confused.
Firstly, though installing the HID's through the wheel wells may seem a bit easier, I found that removing the bumper was MUCH less frustrating and allows for a MUCH better install, especially if you plan on running a relay setup (which I strongly recommend). Now on to business. After reading through this thread, (
http://www.nicoclub.com/articles.php?id=293385 ) there are a few differences between the coupe and the sedan bumper. The sedan has 6 of those pop-up type clips up top, 5 on the bottom and 6 screws on the bottom, along with the two wheel well screws (1 per side). After removing them all, you may remove the bumper (there are little latches that are still holding the bumper near the wheels - just pull outwards and the bumper will unlatch). After removing your bumper, you should be at this point: The red wire that's been circled is the wiring harness/relay connected directly to the battery going down towards the ballast.
Here you can see the harness/relay tied up.
Here's where I ran the harness/relay from the drivers side to the passenger side headlight.
Here's where I bolted on the ballast. There was a random screwhole with a nut welded on (maybe for foglights?) so I took advantage of it and used the nuts and bolts that came with my HID kit. Because there was some stuff in the way, I had to put it in at an awkward angle, but it's holding fine.
Same thing here, except there wasn't anything in the way so I put in straight down with zipties for added security.
And there you have it, just a few things I felt like letting us 4th gen sedan guys know about HID installation And btw, not sure if I'm allowed to do this, but heres where I got my HID's from:
http://forums.maxima.org/group....html. It's a groupbuy over at Maxima.org that 's been going on for over a year now - I have the 6000K 50w kit (extra $15 bucks). Quite possibly the BEST service I've ever had, and they're located about 30 minutes from me here in Houston. It comes with the HID kit itself, big zipties, nuts and bolts, and a relay so the HID's run off of the battery; all of this backed by a 1 year no questions asked warranty on all the parts. Also, the relay only uses one of the OEM wiring harnesses (ie drivers side harness) so you wont have the only 1 headlight comes on with auto mode problem. Feel free to ask me any questions, and it's nice to be part of a new community
Modified by DarkScorpion at 1:06 PM 7/12/2008
Modified by DarkScorpion at 1:07 PM 7/12/2008
