Ive never had a problem with them fading over the years. Im not retrofitting either on a 14 year old vehicle.Azndjay wrote:they fade colors are 2 years of use in my acura rsx , but beats oem changing them every month ..but have you look at HID at the TRS there more price but wayy wroth it . its what people to retrofit a headlight use...http://www.theretrofitsource.com/index.php?cPath=32
Do I need the Error Code Eliminators?zach7685 wrote:DDm is good
^ This is the truth. I love the look but not the light output.patqx4 wrote:HID bulbs in halogen housings is not an upgrade.
Personal opinion.patqx4 wrote:HID bulbs in halogen housings is not an upgrade.
Reality is I dont care. If I wanted to know what others thought of putting HID's in a Halogen housing thats what this thread would be about, but its not. I am just curious what brands others are using and if they have any issues with them.Empty V wrote:It's not personal opinion it's reality.
I always point them directly at the ground. After driving my Caliber for 2 years with HID's its hard for me to see at night with halogens. Hence the reason for changing. The beam scatter depends on how the housing is too. On my Caliber they came with Halogens, but the way the housing is made there is virtually no scatter. Obviously different housings will have different results.BoostMyQX4 wrote:The light output on the HID bulb is much higher then a regular halogen bulb there for making the light output scatter if you use an HID bulb in a regular halogen bulb housing.
Not to mention blinding other drivers front and back, but then again its your choice.
You just said that it's personal opinion and it might be that but it's also a fact and now you say that you don't care about facts. Are you confused? I think you should stick to your roots and put in a 30K kit and slap a NISMO sticker on the rear window.whitedragon551 wrote: Reality is I dont care. If I wanted to know what others thought of putting HID's in a Halogen housing thats what this thread would be about, but its not. I am just curious what brands others are using and if they have any issues with them.
[youtube]http://www.youtube.com/watch?v=5hfYJsQAhl0[/youtube]whitedragon551 wrote:After driving my Caliber for 2 years with HID's its hard for me to see at night with halogens.
Headlights. I wont be doing my fogs. Also what color did you use? My other car has 6K. I was thinking of doing 8K in the QX4.miamiheat3332 wrote:Which ones, fogs or headlights.
How hard is it to see with a 6K compared to an 8K?miamiheat3332 wrote:I had a number of diff colors, right now im running 8k's in the headlights.
Anyways-
Drivers side
Passenger side
Bright output will be from 4300k to 6000k, anything higher then 6000k becomes more blue and you loose light output "BRIGHTNESS" that is why 8000k and higher is consider more of a show light then a driving light, there for some states will not allow you to have anything bluish on headlights and you will get pulled over.whitedragon551 wrote:How hard is it to see with a 6K compared to an 8K?
Here we just cant have flashing blue/red lights.BoostMyQX4 wrote:Bright output will be from 4300k to 6000k, anything higher then 6000k becomes more blue and you loose light output "BRIGHTNESS" that is why 8000k and higher is consider more of a show light then a driving light, there for some states will not allow you to have anything bluish on headlights and you will get pulled over.whitedragon551 wrote:How hard is it to see with a 6K compared to an 8K?
My choice will be to go with 5000k not yellow not blue but a hint of both.
