Dano »
https://forums.nicoclub.com/dano-u2493.html
Fri Feb 26, 2010 8:59 am
I installed my lights, figured out trimming of the white ring was needed just to clear the larger hi/lo combination HID bulb, got everything in, now they won't work. It was 16 degrees when I was installing so i'll wait for tomorrow to mess with it again. I've installed around 14 HID kits, but never a high/low combo. Wiring still isn't difficult, I'm wondering if the relay is bad. Wish they had component testing parameters on their website (ddmtuning) without having to call them for it.
UPDATE: I messed with it more this afternoon, found some pins on the hi-low harness had backed out and the fuse sent with the kit was bad from the get-go (there was a chunk missing from it, plastic and metal both (not blown.) Replaced the fuse, pushed the pins back in and got the low beams to work, switch the pins and got high's only, switched again, and again, all I get is low's only or high's only. Pretty frustrated, i've never had a problem installing any HID kit, but again, this is my first hi/lo setup. Blah, looking into pin orders, have a email into ddmtuning. I'm almost 100% positive it's the hi/lo control module.
But, I have low beams set right now and boy do I love em, combined with my yellow fogs, visibility rocks! Will get pics soon!
