better light output and a bit more whiteish but never compared.G3LO wrote:I see, what you think of 6000K?
Personally i've ordered h8 and h11.G3LO wrote:Well I just ordered 2 HID KITS of 35W 6000K H11 Bulbs for the EX35 2010.
I have a feeling that the HID KIT connection might be switch polarity when it was assembled by the manufacturer. Not sure, but it can happen. I have a relay harness on my low beam and a direct oem connection on my fog lights. I don`t have a problem with blown fuses on my fog lights. Maybe you guys need to separate the 2 lights? Either a relay harness on the low beam and direct connection on low beam or vice-versa... If only installing HID on low beam , then no relay harness is needed.G3LO wrote:Hey AWGD8,
When you installed you HID 6000K DDM Tuning for short beams, are you using a relay harness? I did not order that since I read posts elsewhere that mentioned it is not needed for short beams. When I looked at another post, one had issues connecting the HID's due to blowing too many fuses. Thus, one member replied saying he may need a relay harness. May you ease my confusion?
Thank you!
Hello Marconelly,Marconelly wrote:Finally got my HIDs from DDM. They were fairly quick to ship them, but it took forever for the postal service to deliver them here.
Nevermind that, I have them in my hands now. Still not sure how I feel about drilling the holes in the grey plastic covers, but it's too late to worry over that now. Thinking about it, what should I use to drill a one inch hole in those caps. Hole saw? Spade bit?
G3LO, you have 2010 EX, so did you have to drill the holes in grey covers or did you figure something else out? Someone said in another thread that for 2010 they sealed the headlight assembly completely, and there's no 'hidden' hole anymore to put the HID wires through, like you could in 2009 and 2008 models.
One thing I noticed about these HIDs that I kinda don't like, the wires that I'm supposed to plug in car's original short beam connector are just two naked contact wires :\ DDM's PDF installation manual lists a normal connector as one option, and these two naked wires as another option. Is it really safe to install this like that, just by plugging those two wires into car's lights connector? Everything else has nice rubbery weatherproof insulated connectors.
Yes, there's two wires with bare ends that you are supposed to plug into the connector that normally goes onto the stock halogen bulb. It's on the second page of their instruction manual.AWGD8 wrote:Marconell:
You mentioned about 2 bare wires that hook up to the OEM low beam? I don`t remember any bare wires on my kit ?
