HID Question
SmokeDaT
Car: 2008 Nissan Altima 3.5SE
So I'm looking into getting HID's for my coupe. Both lo's and fog's. I want to know what the difference is if I were to just get 6000K H11 bulbs and swap them out with the factory 4300K in my coupe as opposed to getting a "HID Kit". What is the difference in the two? Is it the same outcome for both scenarios? Is it with the kit you just have ballast and wiring? What is the difference in the two? Thanks in advance to any help
RobPaulson
Car: 2013 Subaru WRX
if u have HID's already (premium) you can simply buy the bulbs and replace them.
if you did not have HID's stock, THAT is when you would need the ballast.
thirdly you can buy an aftermarket ballast if you want, and replace the one you have, maybe there are 'higher end' aftermarket ones? (idk shooting in the dark here)
SmokeDaT
Rob,
Thanks man! That is what I wanted to know. So i'll just get the bulbs.
Am I able to just get bulbs for my fogs also or do i need a kit ?
Coupeguy23
Car: 2006 G35 coupe sport
SmokeDaT wrote:Rob,
you need a kit for your foglight too . even though i have 2.5. im getting some foglight and h.i.d kit for it too
brandonbeeb
hey your best bet is to order d2s bulbs as replacements. the factory bulbs have coveres halfway on them to reduce glare which makes them not as bright. running a d2s bulb wont cause much glare it will just get you alot more light output. all you need to do is make a tiny cut on the base of the d2s bulb to get them to fit, its simple and best way is with a dremel
SmokeDaT
brandonbeeb wrote:hey your best bet is to order d2s bulbs as replacements. the factory bulbs have coveres halfway on them to reduce glare which makes them not as bright. running a d2s bulb wont cause much glare it will just get you alot more light output. all you need to do is make a tiny cut on the base of the d2s bulb to get them to fit, its simple and best way is with a dremel
I actually went ahead and ordered H11 6000K bulbs from DDMTuning
http://www.ddmtuning.com/produ....html
I heard nothing but good things about them. Can't wait to get these !
brandonbeeb
sorry i misread it and thought you had factory hid thats why i said get a d2s bulb. there a good company i do alot of groupbuys with them and the lifetime warranty is always nice
SmokeDaT
Well my 3.5 SE did come with stock HID's, 4300K. I'm swapping out those bulbs for the 6000K I bought from DDMTuning.
Chuck2417
Car: 08 silver coupe 3.5se
HID's for the foglights, any idea where the kits are and any ideas on where to mount the ballast? Does anyone have a video or post on installing HID foglights for the altima coupes?
SmokeDaT
Chuck2417 wrote:HID's for the foglights, any idea where the kits are and any ideas on where to mount the ballast? Does anyone have a video or post on installing HID foglights for the altima coupes?
HID Fog's: http://www.ddmtuning.com/produ....html
Definitely can't beat lifetime warranty. As far as where to mount the ballast, i myself am not sure. There is a sticky with instructions on installation through the wheel well and it has pics of where people mounted it.
http://forums.altimas.org/zerothread/293744
Chuck2417
Thanks, what size are the fog light bulbs? are they H11's?
SmokeDaT
Chuck2417 wrote:Thanks, what size are the fog light bulbs? are they H11's?
Yeah, the fogs are H11's
Chuck2417
Thanks!
Does anyone have any recommendations for placement of the ballast or installation instructions? I do not want to have to get a mechanic to do it and pay them 100$ or so to install the lights. Any ideas would be appreciated.
Chuck2417
Any suggestions on color for the HID fogs? I currently have just the stock HID's in for my car (premium package).
