HID Question...couldnt find any answer through search!
All things Altima Coupe.
Rmuth25
Car: 08 Altima Coupe 2.5s CVT [Premium & Tech Packages]
I have an HID question that I could not find through search.
Now where I live I use my high beams at least 40% of the time, maybe even more, so it makes sense to me to make my lo and hi beams HID. However, I thought there was something like HIDs take a while to warm up or something(I am new at this so I really have no clue) so in other words, when I switch to high beams will there be a time without lights? Isnt the stock HIDs on the 3.5 coupe HID for low and hallogen for hi, thought I read something like that in the manual. This is probably a really dumb question, but I am just curious.
Also, does anyone have any recommendations on which ones to get(I have a 2.5 coupe)? I have no real idea what the like 3000k 6000k or whatever means.
I am really eager to modify my car now since some person just got the same exact car as mine at school. Well same color, he/she doesn't have all the "goodies" in it though.
Shift_Altima
Car: 2008 altima coupe 2.5s 6 speed
the HID's only take a few seconds to fire up.. maybe 20 seconds or so until they're fully ready. The # pretty much corresponds to color. 3000k is yellow.. 4300k is yellowish white.. 5000k is crystal white.. 6000k is white with a hint of blue.. 8000k is blue.. 10000k is purplish.. 12000k is purple.. and so on.
Hussain
Car: 08 Altima Coupe 3.5se CVT
it is also important to point out that the higher the number, the less usable light. like people with the 10,000K look bright but the 5000k will give you much better visibility. the 4300k is the stock temperature for cars with HIDs (premium package). i have 5000k HIDs on my car and they're whiteish blue..... honestly i recommend 4300k or 5000k.
boystar22
Car: 2008 Nissan Altima Coupe 2.5S
It also isn't generally recommended to turn the ballasts off and then off again rather quickly, so for high beams turning them off for an on-coming car, and then flipping them on again isn't ideal to their life-span. I also believe since they have to warm up you will loose your flash to pass feature; well maybe not loose, but you'll have to hold it for a bit before they do anything, so flashing the idiot that is about to, or has cut you off won't be as effective. Most high-end cars that have HID's for highs use a bi-xenon projector, where the movement to the high-beam just removes the cut-off flap on the lens; also they generally still use a halogen bulb as well for high beams due to the delay in the flap moving.
mikegtr06
Car: 1995 180sx
just get the brightest H9-65W that are non hid.
Bmore-coupe
mikegtr06 wrote:just get the brightest H9-65W that are non hid.
thats what i was thinking about doing, where would you get them
SamC.altimacoupeneedshelp
Car: 2008 Nissan altima coupe 2.5s w/ moonroof, convieince package...i need websites that have the things
If i want my headlights to be blueish but not tacky blue is 8000k good or to much, i basically want them to be the color of a high end car
Blackmobile
Car: 2008 Altima Coupe 2.5S Super Black
I wouldn't recommend anything higher than 6000k. 8000 would be more purpleish than blue. I'm pretty sure though that most "high end" cars use 4300k as they're the brightest.
so 6000k will shows some blue in it?
bina12834
Car: 06 G35 coupe
my 5000k's have some blue-ish tint
kuhan
Car: 2008 Nissan 350Z Enthusiast 6spd
I have 6k for low beam and 5k for fogs. I personally like the look of 6k more.
do your 6k's have blue in them or are they white?
HuyyNguyen
Car: Nissan Altima Coupe 2.5s
I appreciate that, but those colors arent the same as the altimas, on the altima 12k is purple
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
i have 6k headlights n fogs... xentec..i dig em... not really blue... it varies depending on brand etc.. its not like we are talking about scientific parts here
would you say there is any blue in them at all?? or is it straight white, do they resemble the HID's from luxurios cars lights. That bluey whitish look...lol?
Shift_Altima
Sam. The reason there's a nice tint on luxury cars isn't just the light bulb. it's that they have projectors. Projectors break the light because they act as a prism so at differnt angles u get white.. blueish white.. and purpleish white. Reflective housing with HID bulbs won't give u that look it isn't possible
zilla19
SamC.altimacoupeneedshelp wrote:would you say there is any blue in them at all?? or is it straight white, do they resemble the HID's from luxurios cars lights. That bluey whitish look...lol?
I have 8000k with slim ballast; the center is white like the picture posted by HuyyNguyen from above, but the surrounding area of the light in front of the car has very little hint of ice blue (look at 10000k, but a lot lighter). As for when you look directly at the headlight, my 8000k looks like the low beam in the 8000k picture. If you want to go for that bluish look, I'll say go for the 10000k. You might loose a little bit of brightness (still a lot better than stock) and you might attract some unwanted attention from the cops though.
HuyyNguyen
SamC.altimacoupeneedshelp wrote:I appreciate that, but those colors arent the same as the altimas, on the altima 12k is purple
it doesn't matter about the car, it matters about the brand of the HIDs you are buying....whatever thousand k you buy it will be either exactly the same or very VERY similar to the pic i show
o i gotcha thanks
mikegtr06
Car: 1995 180sx
6k for the win
So you like your 6k?
bina12834
Car: 06 G35 coupe
i have Xentec 5000k's in my lows and fogs, and this is what they look like.....the color temps arent the same throughout the different brands.....5000k Xentec's may look different than 5000k X-Lite
mikegtr06
Car: 1995 180sx
SamC.altimacoupeneedshelp wrote:So you like your 6k?
since i have got mine and shown them off soooo many times. i got 4 others to buy them for their cars and 2 more bikes.
l2ichal2d
Car: Altima Coupe 2.5s
xentec 6000k ftw way brighter at night for me ... and all those people driving toward me
