HID Projector lights
nissanroguejust
Car: nissan rogue 2015
Just got the 2015 rogue sv...would like to convert the halogen lights to HID or similar
anyone have experience?? photos?
yearoftherat
Car: 2015 Nissan Rogue SV AWD
If your vehicle came with did not come with the LED projector headlights, HID kits are not recommended because of the reflector style housing. You will get a lot of glare and blind any oncoming cars.
http://www.danielsternlighting.com/tech ... sions.html
http://clubroadster.net/vb_forum/20-ext ... there.html
Leo2005
If your vehicle did not come with led projector headlights then here's the option:
http://rover.ebay.com/rover/1/711-53200 ... =824&kw=lg
darkelipse04
I was looking into the same thing, my Rogue is all reflector and I don't want to blind anyone or get pulled over for modifying lights "illegally".
The $750 eBay option looks nice, a little more than I wanted to spend but I guess in this situation we are limited in options.
darkelipse04
Leo2005 wrote:If your vehicle did not come with led projector headlights then here's the option:
Does your product with any kind of warranty/guarantee?
Leo2005
Yes, pm me throw forum or ebay. This is not a sales forum so we can not discuss any sales in here.
darkelipse04
Leo2005 wrote:Yes, pm me throw forum or ebay. This is not a sales forum so we can not discuss any sales in here.
Sent you a message on eBay.
xtrailmty
Actually you can buy any HID kit and use a H11R bulb which comes with a special shield that will make your beam patter almost exactly as your stock halogen. It will cost about $75-$100 the pair and it really worth it.
darkelipse04
xtrailmty wrote:Actually you can buy any HID kit and use a H11R bulb which comes with a special shield that will make your beam patter almost exactly as your stock halogen. It will cost about $75-$100 the pair and it really worth it.
I tried searching for this but have had no luck.
Any suggestions on an exact name or what I can search by?
xtrailmty
X1tymez
Car: Nissan Rogue 2015
Any real life photo on cut off line? I do wanna see this on reflector.
followingnfront
Car: 2017 Maxima S
Do a projector retrofit. It can cost anywhere fro $250 to $1000+ depending on what kind of retrofit you want to do. But $300 can get you the parts for a great retro
Go to Theretrofitsource.com
I have no affiliation, but have used there products before and they are great.
Also, go to hidplanet.com
Tons of helpful info in there
frankybabi
Car: 2014 Nissan Rogue S
So I'm looking into upgrading these halogen bulbs to an HID kit.
I recognize that they are an H11 bulb. 55watt
But I'm having trouble understanding which relay I should purchase..
I don't want any fuses going out, being that's it's a brand new car- this is the only upgrade I'll be doing. (or so I think this way now lol)
Can anyone help me??
Should I be getting the 'Single Relay' or the 'Dual Relay' ..?? and what does it mean?
Also, Should I be purchasing the 55 watt??
Reason: Merged with existing thread
xtrailmty
DO NOT get the 55W kit, its too much current in the first 10 sec. for your stock harness, get the 35W and you dont need the hid harness just order the h11 35W kit and you are done.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
frankybabi wrote:So I'm looking into upgrading these halogen bulbs to an HID kit.
Oops, missed this one. We've got this thread started, and there's this topic as well: 2014 Rogue's bulb replacement / LED upgrade
--------> READ BEFORE CREATING NEW THREAD! <--------
We have an incredible SEARCH feature on this forum.
MERGED.
frankybabi
xtrailmty wrote:DO NOT get the 55W kit, its too much current in the first 10 sec. for your stock harness, get the 35W and you dont need the hid harness just order the h11 35W kit and you are done.
Will I blow any fuses without the harness? if the 35w kit is purchased..?
xtrailmty
no, remember your stock system is 55W and can hold 85W without any problems for a few seconds. Go for it.
frankybabi
so if I purchase the 55w kit, do you recommend a relay with the fuse?
xtrailmty
i do not recommend the 55W application ballast, it doesnt matter if you add the harness with the fue or not cause you will use stock harness anyway and the headlight assembly will start to show sign of melt later.
frankybabi
Ok, I appreciate the input! Just wanted to go with the right equipment, the last thing I want are things melting
xtrailmty
yeah, no problem, i was the first one to sell hids in Americas and ebay loooooooong time ago, so i know a few things about hids lol.
nicolasl46
Car: 2015 Nissan Rogue SV with Premium Package
I figure I'll ask here instead of opening a new thread. I have a 2015 Rogue SV with premium package and I'm looking to upgrade the headlights. I found some cool looking headlights on alibaba, but I really like the look of the OEM projector headlights (full LEDs?) my question is, are they plug and play? I remember when I had my VW that if your car came with factory halogens and you wanted OEM xenon HID headlights, you had to replace a control module on the car. Any input is appreciated
Return to “Rogue Forum”
