Natedogg1701 wrote:thats exactly what it is, a magnet, very low powered magnet but it does the job. and i believe its the fact that the cradle that holds the bulb keeps the light from hitting the lower reflector inside the headlight housing, doing so keeps the light from being relfected high and into the faces of traffic. when its foggy out i can see the beam very well, and it shoots out a very sharp, clean cut beam, and when i bit highbeam it changes to a wide spread angle, but still has a specific beam abgle, not just a spray of light. i spend 80.00$ for my kit shipped, and it was well worth it.
I just installed my THIRD hid kit, since June.
The first burned out a bulb. Second one is spraying too much light up. No cutoff.
And my third? Well, we'll see. I literally just finished installing the bulbs and ballast before coming online. Unfortunately, I didn't swap out the relay wiring harness... and the plug that controls the magnets are different.... so, for the time being, I have no high beam.
In any case, I noticed immediately, the bottom portion of the headlight housing is darker than with my 2nd kit. So, I'm hoping it's like my first kit. It was BEAUTIFUL, just like yours Nate. It had a very sharp cutoff.
In another post on the forum, I wondered if it was because of the shape of the "shield" around the bulb... my first kit had flat sides to the shield. the second was completely curved. The third is also completely curved.
But there is one thing different from the 2nd to the 3rd... the opening in the shield for high beam. In the 2nd, the opening is bigger (simple rectangle). The 1st and 3rd are almost as big in the middle, but the sides are smaller (kinda like someone put a tall square on a short but wide rectangle).
