When first installed they both turned right on with the headlight switch right away. Yesterday though I noticed my drivers side headlight was not lighting up.
I tried it again when I got home. If I turn the lights on real quick the passenger side headlight works, but not the drivers. If I turn the parking lights on and wait a second or two then turn the lights on the passengers side light comes on and then the drivers about a second or two later.
I installed the kit with a 40amp relay on both sides, I'm hoping it is only a bad relay and will test that later when I finally get some time. I would love to hear any (non-negative please) feedback or ideas. Let me know if you have had this problem and what it turned out to be, I'll let you know what I can figure out with the volt meter.
Any help will be greatly appreciated!
I'm just hoping it is not a ballast going out already.
