HID popup headlights
VujadeMotorsports
Where can I get some HID popup headlights for my RPS13? I like the ones on clearcorners.com .. but those are really expensive, i've done a good deal of searching.. but havent found another. Also, I have seen the popup replacement on jSpec.com .. and I don't like those.. nor do I want to do ANY sivila conversion if I can do a popup HID setup.
Thanks!
stillmatic
Real HID's are expensive and often get stolen.
You can do an H4 conversion if you don't want to spend that much money. Do a search for 240sx headlights on eBay. I've seen them go for less than $15.
BTW, an RPS13 is a Japanese chassis code for the 180sx with SR20DET.
VujadeMotorsports
I want REAL HID's.. I am not concerned with any other factor. Where can I get them?
duey
yeah what he's saying is go on ebay to get the sealed beam h4 conversion lights. It's basically what you have now for headlights but the actual "bulb" is not fixed and CAN be replaced with H4 (9003) HID kits readily available anywhere.
dr!ft
Car: 1988 Isuzu Trooper II, wish it was a 240...
Although a bit expensive ($1800 - :eek: ) Clear Corners has something you might be looking for...
http://clearcorners.com/produc...wpro/
But a much more affordable solution would be the McCulloch HID system ($549 H4 bulb kit). Obviously, you'd need the H4 conversion kit first for this to work...
Find the McCulloch kit here...
And here's a complete install of the McCulloch kit done by NPM!
[s3]
[QUOTE]Originally posted by VujadeMotorsports "]"I am not concerned with any other factor."
get them from clearcorners.com, if you are not concerned with any other factors.
ilikenissan
Car: paintball, cars
The red S13 on clearcorners site look like an older camaro :)
Flybert
Sylvania was having a deal on H4 HID stuff for $300. Do a search on zilvia.net and you might find it. There was a review as well.
yeswepromise
JDMRICE looks like a camaro?
gibbo80
there was a post awhile back where someone was making them, search and find that
ilikenissan
yeswepromise wrote:JDMRICE looks like a camaro?
With the lights up from the front yes.. And isnt that the old one anyways? I thought his new one had an S15 face and was more marroonish?
