I bought a 2001 QX4 about a month ago w/ 115K. Runs pretty well, but I'm having problems with the HID headlights. They're stock.
The right one would flicker and go out when I turned it on.
I read some stuff online and someone said it was probably the the ballast.
So I took the grill off and took the lights out and switched the ballast and put it all back together.
Turned on the the lights and the same problem occurred on the same side (right).
So not the ballast.
The bulb? I figured it'd either work or not ... not work intermittently. That really didn't compute, but I went and bought a new one.
I stuck it in and it worked. Turned the lights on and they stayed on.
For about 3 days. Then the right one went out.
Now no flicker. It just doesn't turn on.
Next up is the switch on the steering column according to the forums here. Yippee.. another $100ish. I'll try that on pay day next week.
Until then, I'm curious... is it possible to replace the whole HID setup with plain old halogens?
Are there plain halogen lights available for QX4?
OR Are the moldings of a 2001 Pathfinder's non-HID lights the same & wiring compatible such that I could switch those?
I feel like just getting rid of $$$HID$$$ system altogether if it's possible to do so.
Thanks!!
