HID lights and clock
epickakashi
Car: 1993 Nissan 300ZX 2+2 Twin Turbo
hey does anyone know where i can get a HID kit for a 1993 300ZX and how much does it cost. and the other question was does anyone know how to fix the clock in the car because when i got my car the clock was broken and i was wondering if its fixable or do i have to replace it.
lilskirk23
Car: 1999 Volkswagen GTI VR6 MK3
if you really want to spend the $1600 for the HID headlights you can get them on ultimatz.com.
heres a direct link to the page:
http://www.ultimatez.com/shop/...22820
i dont think that its really worth the money for them... you would be better off buying halogens or something like sylvania silverstars. the clock i am not sure about.
HKSdrift3r
ebay~ $120.. cant beat those for the price and prob the look your goin for.
freakonaleash1187
Car: '93 300ZX N/A, '97 200SX SE
You can either get a cheap kit off ebay or there are a lot of kits out there. As for the clock, you will just have to get another one, but a new one cost a pretty penny.
lilskirk23
i looked on ebay because i was curious to see them.... the kits i saw were only the bulbs... not the whole headlight housing.
freakonaleash1187
Thats what HID's are..............
Unless you want to buy the '99 JDM Xenon headlights, which are $1600.
lilskirk23
yes i know but my point being that you should go with the kit that has the housing because HID's/ xenon's burn hotter then regular bulbs and can actually melt the plastic or can melt the sealant around the headlight housing causing them to get waterlogged whenever they are exposed to rain or fog. wouldnt be pretty either way.
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
Actually, they run cooler which is one reason they last longer. However... if you get one of those kits you have to be careful about glare. Most of the time halogen housings cause more glare with HID's. You either have to aim them low, modify the cutoff (in the projector), or do a retrofit using true HID projectors.
I'm not sure how the Z housing reacts to HID's but if there's any glare I'd work on getting that out because it would suck for oncoming drivers to have to go through the glare of an HID.
lilskirk23
i stand corrected. i have heard that they burn hotter before somewhere but i guess it wasnt a credible source... well.. atleast i learned something new.
mtcookson
1992 Iinfiniti Q45
and much much more
Yeah, they actually run a higher voltage but only take about 35 watts.
epickakashi
hey are those kits dot legel because i heard that putting hid kits on cars that are not ment for them makes the lenght of the beam shorter and it blinds oncoming cars do you know if thats true because i really want to buy a kit but i need my car because its my daily driver.
300zx_tt
Car: 300zx twin turbo
I hate to be mean but I'l jsut get to the point.
A. Have you heard of search?B. You can repair your clock.C. Have you heard of http://www.twinturbo.net? you can find HID kits there and used clocks in the classified section for good prices.D. Don't register...yet.
mtcookson
1992 Iinfiniti Q45
and much much more
epickakashi wrote:hey are those kits dot legel because i heard that putting hid kits on cars that are not ment for them makes the lenght of the beam shorter and it blinds oncoming cars do you know if thats true because i really want to buy a kit but i need my car because its my daily driver.
Definitely illegal, especially the "kits". Depending on the housing, they can cause quite a bit of glare to oncoming drivers. Having projectors help, but the design is still different between halogen and HID. You can sometimes modify the projector to work perfectly with an HID bulb by moving the cutoff plate, which requires taking the headlight apart. The two safest ways of doing it would be to get the HID headlights made for the Z (the expensive Nissan ones) or doing a retrofit.
Technically putting in any light that is brighter than stock is illegal but as long as there's no excessive glare you can usually get away with it without any trouble from cops.
mahchu07
Car: 1993 300ZX NA
Does anyone know of anybody who has actually bought the $1600 '99 J-Spec HIDs??? They look so clean.
epickakashi
how would i do a retrofit on the Zs headlights and how much would that cost for parts?
