HID lamps
Larry Pengilly
Car: cars, and radio control anyting
Dont know if this will help much, but if you are trying to get the angry eyes look with HID lamps, just go to the junk yard.
get these parts, bulbs and ballast for a BMW 3,5,7 series.
then take your stock S14 low beams out, and smash the bulb out, you should just have a flat base, then remove all connector parts and drill a hole through the base large enough to epoxy the BMW HID bulbs into the S14 bulbs,
Use high temp epoxy and make sure you dont touch the glass on the HID bulbs.
Wait till dry then install them like standard bulbs, hook up ballasts and get your FSM and wire the balast in.
turn them on, you should now have that cool BMW HID look for around 50 bucks. (of course Depending on junk yard)
Then for that angry eyes look just get some "eye liners" I think that is what they are called.
and whalla a custom headlamp that you can show off.
I have done this on both of my cars now and have had no problems with them whatso ever.
later
Larry
Larry Pengilly
oh yeah I did this on a S14 96 model
later
rico05
Car: 1992 RMS13 w/ CA18DET
I bet this could be rigged on an S13 with H4 conversion. This may motivate me to get off my *** and get new headlights (I bought the hiper white Wal Mart lights on accident when one of mine went out) Good ideas!
sxseguy
Car: Makin' it go faster!
Post pics please.
240tek
Car: 89 fastback
I'm thinking of putting this in my s13 fastback. What about aiming them. How do you properly direct the beam? I don't think it will be too easy to aim them properly with the h4 conversion. PEACE. Tek.
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
pics pics pics...:)
-Dan
240dreamer
Car: 95 240sx SE
maybe write up an install....and show us some pics!!! good idea!
vuse1
hahah, i did this as well but a little bit different. i already have 8000k HID's, so i took out my hi beams lights busted the bulbs soldered on some amber bulbs onto the leads off the stock 9005 hi beams, and spliced into my corner light wiring. so the end result is i have amber corner lights and amber on the inner parts of my headlights. it looks clean until i turn my head lights on then you cant even see the amber bulbs....i'll take some pics and post them
Dano
yeah post pics, im interested in seeing that vuse
-Dan
vuse1
ok, i took a bunch of pics and they are saved to my comp, but im a total noob when it comes to posting pics. i tried putting the img tags around the image link but they showed up as red X's. can anyone help ??
i remember someone saying that nico will host pics? if thats true, do they still host? thanks
Dano
u can host them with NICO in the member's ride section. then put this around the address:
(without the spaces)
-Dan
240tek
Car: 89 fastback
I can host them. Email me. [email protected] PEACE. Tek.
fuzion
Car: Cars.. Web/graphic design.. Yuppp
Are these actually Xenon head lights or just "xenon looking"
If they are real xenons it's illegal :)
To be legal they must:- Must be auto leveling- Must be equipped with a washer system- Must be correctly aligned to meet international regulations
Dano
all HID lamps that arent OE in their respective vehicles are 'illegal'....
-Dan
vuse1
thats my car. I changed the white balance on my came for some of the pics. what do you think about it?
fuzion
Thats alot of yellow.. looks like an old ford ;)
vuse1
hahah, yah it looks similar to an old mustang. but in person there is a clear difference between teh amber in my headlights and the yellow of my fog lights, plus i messed with the white balance.........my 8000k HIDs help a little :ylsuper
fuzion
I want some better lighting... stupid sealed beams!
canadians14
yeah those look awesome, i was seriously considering ordering a set for my 1996 240sx but i sadly realized that i can't..... well not easily anyways. Because my car is a canadian model the daytime running light module restricts the voltage during the day, not allowing the beams to light up properly. Because the daytime running light module restricts the voltage to ~7V often one light will not ignite or even both. So unless i want to run without DTRL's (illegal in Canada) i am out of luck. Hope this saves some problems for anyone here up north. Or if anyone has found a way around this other than scrapping the module and turning on your highs all the time please let me know.
canadians14
Its the first incident in this thread :
http://proxenon.com/resource_details.php?id=22
wickedpelf
Car: 1991 240sx with super hicas
Anyone thinkin about tryin the HID conversion on a s13?
