Hid install
cknaack
Car: 2008 Nissan Rogue SL
I used to have a titan but ended up trading it in when found out my drive shaft was bent, long story but anyways i used to have hids and i used a can bus system to get hids on it, but now i have 08 rogue. can i just use a basic hid kit. i know when i installed my old ones on nissan titan i never had to aim them just plug n play and worked perfectly. I was hoping i could do the same on rogue. and same for fogs
Pescakl1
Car: 2008 Nissan Rogue SL FWD
Iridium Graphite
You can do the same with the Rogue.
I will however advice you to aim them a little lower, due to the glare the HID produces in the reflectors. You will still see better than with regular halogen.
Return to “Rogue Forum”
