S-13 »
https://forums.nicoclub.com/s-13-u65397.html
Mon Jul 16, 2007 10:50 pm
duno where the write up is but I would start with an H4 conversion kit first to get rid of the sealed beam bulbs. These can be sourced at any major auto parts store, ebay, or your local tuner garage's. Once you have the kit youll have to decide on bulb size, but thats not a problem since your H4 housings will of course only take an H4 bulb. Next youll want to decide on the light intensity you want your HID's to look. Almost all manufacturers use the typical 8000, 10000, 12000 etc to differentiate how white, blue or purplish the light output will be. Some manufacturers use this method to refer to the kelvin scale in regards to how hot the bulbs burn but I also belive brands like PIAA only use them to differentiate color. Basically the higher the # the closer the bulbs output will resemble actual sunlight.
oh and oldschool kits come with ignitors the newer generation HID kits shouldnt need them
