HID help
bknewtype
Car: 2003 Infiniti G35 Coupe
hey guys im experiencing a problem with my left headlight. my problem is that the left HID bulb wont turn on. i tried 3 other bulbs and none of them worked, so i know its not the bulbs problem. im afriad it might be the ballast. everything else works ( turn signals, side markers, clearance strip) only the left HID bulb wont turn on. is there a way to check if the ballast went? or could there be a more simple solution to the problem? my headlights are 03. thanks in advance.
telcoman
bknewtype wrote:hey guys im experiencing a problem with my left headlight. my problem is that the left HID bulb wont turn on. i tried 3 other bulbs and none of them worked, so i know its not the bulbs problem. im afriad it might be the ballast. everything else works ( turn signals, side markers, clearance strip) only the left HID bulb wont turn on. is there a way to check if the ballast went? or could there be a more simple solution to the problem? my headlights are 03. thanks in advance.
Did you check the FSM?
http://www.nicoclub.com/FSM/G35/Coupe/2003/lt.pdf
See page 23
A call to the Infiniti service department at the dealer might give you an idea of what is wrong if its not the bulb and the cost.
Telcoman
Poyzinous
Car: 2004 G35x Premium 1976 Classic Red 36 inch #18 Radio Flyer Wagon...
if there is no wiring issue, your ballast may be to blame. they are pricey though.
audtatious
ebay may be a good place to look.
http://shop.ebay.com/?_from=R4...ories
