HID Help
Renovatio
I just installed a 6000k HID kit for my M35X and the light output is going out to the sides not straight on like the haolgen bulbs did. So what do I do now? I know that they can be adjusted up and down but How can I fix this?
thanks
nmgoodthing
Car: Brilliant Silver 2003 M45 / Pine Silver 2004 Lexus GX470 / Black 93 300zx TT
This is because your reflectors are not designed for HID.
You are getting glare. You also probably installed a DS2 bulb which is designed for projector type housings, not complex parabolic reflectors.
Even if you used DR2 bulbs you still are going to get glare and uneven beam pattern.
Your only solution is to get some type of shield or retrofit some real M45 HID projectors.
auditech10
Car: 03 M45
dittoyou have to realize that you put bulbs that put out 3x more light than what was in there before. you can try to adjust them to the inside and lower a bit but you can only go so far. also make sure the bulbs are installed correctly, if they arent they hit the reflector in a different manner and scatter the light wherever it wants to
Renovatio
yea prob was needed H1 bulbs not D2s now it works fine
auditech10
Car: 03 M45
So I am confused as to what you found out? You tried to install factory HIDs into your halogen housings?
Renovatio
I bought D2S bulbs stupidly when my halogen housing are OEM H1 so I replaced the H1 halogen with H1 HID's and added the ballasts
auditech10
Car: 03 M45
ahhh, ok. silly mistake but as long as you got it figured out
nmgoodthing
You mean you purchased HID capsules with a rebased H1 base. No OEM manufacturers make HID capsules for halogen bases. You can find a few companies that might take a Phillips or Osram bulbs and rebase them but most are cheap asian stuff. Be warned.
auditech10
Car: 03 M45
I dont think he thought that, he just said that the OEM housings are H1 halogengood looking out though
