^+1 but be careful - the ballast produces what...10? 20000 volts? don't get zappeddroppedmax91 wrote:the ballast should be connected to the headlight, check voltage at the bulb if u have volts after the ballast then it would be the bulb bulbs are more common,taking out wont be bad about half an hour hope the helps
nissan tech
