z32S wrote: ↑Fri Mar 25, 2022 10:00 pm
Optics / lens are different in Halogen / HID... whether swapping HID bulb to Halogen / vice versa will result in a change in beam pattern. If you look closely at Halogen bulbs, the light beam shoots out at '360 degree' while that from an LED is not (usually a headlight LED bulb has 2 LEDs aligned on flip sides.... some LED backup bulbs for instance are arranged in a more 'circular / 360' layout though).
Think about what you're implying in terms of your original statement about blinding oncoming drivers. Yes, LED's have a slight "dead spot" in the pattern at the very top and very bottom, but a halogen will actually emit more light on the driver-blinding high axis than an LED. The flatter pattern is an asset and not a liability in those terms. "Blinding" LED's are rarely an issue of beam pattern unless an idiot installs them horizontally. They're more often a matter of an idiot simply using a bulb that's too bright. Some LED's output 7 times the lumens of an equivalent halogen, which is frankly ridiculous.
Bulb socket isn't the concern as they are vastly available in various types. Any btw, yes some 'made in China' products aren't up to par, but if that country can send astronauts to space, they are capable making quality products. Apple products are mostly 'made in China' too, and to me the quality is pretty good. GM / Ford makes some highly unreliable vehicles too (some are still great like the older F150s)...and so are Land Rovers / Jags or even Aston Martin.
In a previous life I dealt with "cracked cup syndrome" out of the Far East every day. Materials, construction, and QC for stuff made in China will be
exactly as good (or bad) as the designer specifies. If your sample cup has a crack and you don't specify that the production units shouldn't be cracked, you'll get a million cups with an exactingly-reproduced crack. The best common example I can think of is Pittsburgh tools at Harbor Freight. The Pittsburgh Pro stuff is outstanding, I have a set of chrome combo wrenches that have resisted everything short of C4 and come up smiling. Right beside them on the shelf are regular Pittsburghs which will probably break if they look too hard at a sledgehammer. You get what you specify, and HF simply has stringent specs for the Pro line and probably none at all for the regular Pittsburghs.
