HID Fuse Relay Question
bina12834
Car: 06 G35 coupe
where would i put the O-ring connector on the positive side battery connector....where the blue arrow is pointing or where the red arrow is pointing? Also i can hook up 2 fuse realy's (1 for lows and 1 for fogs) to the positive side on the battery, right? Thanks.
audtatious
I'd use the red arrow location as it would be easier to route the wires while keeping the red plastic protector down over the terminals.
bina12834
Car: 06 G35 coupe
so it doesnt matter which connection i use then?
audtatious
They are both battery connections. One is the wiring to terminal nut and the other is simply the nut to the bolt that holds on the battery terminal to the battery post.
kuhan
Car: 2008 Nissan 350Z Enthusiast 6spd
I connected both hid fuse relay (+) O-rings to blue arrow. I think I used a 10mm socket to take the nut out and put both O-ring connectors in there. And I connected the (-) O-rings to the negative terminal.
bina12834 wrote:where would i put the O-ring connector on the positive side battery connector....where the blue arrow is pointing or where the red arrow is pointing? Also i can hook up 2 fuse realy's (1 for lows and 1 for fogs) to the positive side on the battery, right? Thanks.
bina12834
Car: 06 G35 coupe
thanks guys.....i ended up connecting both (+) wires to where the blue arrow was pointing...my (-) wires werent long enough to reach to the battery, so i grounded them on the bumper cross bar.
mikegtr06
Car: 1995 180sx
ok so i need to get some relays and is there any that are better or worse for the lights.
i have a 2.5s that came without fogs, and am going to run the lows with an hid kit on the driver side relay and the fogs with an hid kit on teh passenger side relay.
would that cause any issues ? i have read that other people are doing it.
any help would be appreciated,
thanks
BlackNWhite
Car: 08 Altima Coupe
I've connected both of my relays to where the blue arrow is pointing. But now that auditatious pointed out that the red arrow would be easier... I feel stupid.
http://motors.shop.ebay.com/merchant/hid4today
^That's the guy I use. If you search e-bay it seems pretty much everyone offers about the same product. (at least by looking at the pictures) But this is the guy I've ordered from and have always been happy.
I also used a relay to run HIDs to the fogs off of the passenger side and no problems yet. *Knock on wood*
Only bad thing is if you start your car with the headlights in AUTO position... sometimes all four bulbs won't light up. I always turn my car off with the lights in OFF position and once I turn the engine on, I turn the lights to AUTO. That method has never failed me yet.
mikegtr06
Car: 1995 180sx
thanks thats what im gonna try.
bina12834
Car: 06 G35 coupe
BlackNWhite wrote:Only bad thing is if you start your car with the headlights in AUTO position... sometimes all four bulbs won't light up. I always turn my car off with the lights in OFF position and once I turn the engine on, I turn the lights to AUTO. That method has never failed me yet.
isnt the point of using a relay so this wont happen?
BlackNWhite
Yea... but I assume the power draw of the HIDs at the same time is just too much for the battery to handle.
Besides, another point of the relay is to protect your stock wiring. I once had the HIDs connected without a relay and I blew something when one of my ballasts fried and my passenger side wouldn't work, even when I returned it to stock.
bina12834
Car: 06 G35 coupe
with the relays drawing power directly from the battery, it should be more than plenty to fire up all the ballasts no problem when starting the car with the lights on Auto
